martin809 Posted December 6, 2013 Share Posted December 6, 2013 Just wondering, what have you used to replace the A/C heat tubes behind your dash. I am talking about the hoses that go to the vents. The ones the air goes through. Hope this makes sense. Thanks for your help Link to comment Share on other sites More sharing options...
jimoshel Posted December 6, 2013 Share Posted December 6, 2013 I've always found what I needed at the JY. However if you really can't find what you need, try the plumbing dept at the building supply center or hardware store. Check out the rubber hoses for garbage disposals washers, dishwashers, etc. Link to comment Share on other sites More sharing options...
martin809 Posted December 6, 2013 Author Share Posted December 6, 2013 Thanks, I didn't think about those. I checked out others like the clear tubing, but just not sure about that. Link to comment Share on other sites More sharing options...
yxmj Posted December 6, 2013 Share Posted December 6, 2013 If you are in a bind you might try the hose used under the hood on the windshield washer fluid nozzles.....the only thing that might be an issue is that most vacume lines are a bit heavier wall to keep the tubing from collapsing in on itself under vacuum..... a second thought is the tubing that comes with air shocks.....you would need a small piece of hose at each end for a coupler.....but like i said in a pinch it might get you going . :MJ 1: . Link to comment Share on other sites More sharing options...
