zackcj7 Posted November 11, 2013 Posted November 11, 2013 I have a Ford 8.8 that has been regeared to 4:56 with a rebuilt factory limited slip. It is set up for a swap into a XJ but could go in a MJ with the correct spring perches. It comes with the disk brakes, calipers, and lines, and an Explorer drive shaft. Tubes are welded to pumpkin. $550 I also have a new in the box Barnes 4wd 8.8 install kit that i'll sell for $90 to go with it.Consider trades or partial trades for the following:Long arm set up for XJ/MJAdjustable control arms for TJ, Johnny joint only, Curry,Savvy,Clayton,etc.Adjustable track bar for XJ/MJCurrie Anti-rock front swaybar for TJ,XJ,MJ
Archived
