Motor Swap... What Else Will I Need To Do??
here's my prior thread: http://comancheclub.com/topic/37922-motor-swap/?do=findComment&comment=381854
I'm swapping in a HO motor from a 96 while using parts from the renix motor which cruiser54 has nicely made a list of what all is needed instead of me wasting time typing everything, that list is seen here below..
Cruiser’s HO into Renix Swap
This swap is easier than some will lead you to believe, generally those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it as swapping in a long block.
The HO and Renix have some differences but none that can’t be overcome very easily.
Any HO engine from an XJ or ZJ through 1998 can be used. One running change was that the rear of the head was no longer drilled and tapped for the temperature gauge sender beginning in the 96 model year. The sender can be relocated to the threaded hole in the thermostat housing taken from the HO engine. You’ll have to extend the wire to that location. Some brave souls even drill and tap the HO head for the sender.
You will be using the intake and exhaust manifolds from your Renix, along with all your sensors and wiring. Since the intake ports of the HO are slightly different, you use the Renix gasket. Exhaust ports are identical.
You will need to use your Renix distributor as it is different than the HO because they use different fuel management systems. The  flywheel or flexplate from the Renix must be used so your CPS gets the correct signals. The valve cover from the Renix allows you to keep your CCV system intact and requires no modifications.
The HO block will have a plug in the coolant galley on the driver’s side of the block, closest to the front, which needs to be removed so your Coolant Temp Sensor can be installed in it’s place just as it is on the Renix. It requires a 5/16” square drive or a modified 3/8” drive that has been ground down to fit. Do this before installing the engine.
As for the knock sensor, which is located just above the oil pan on the driver’s side of the engine about mid way, all the blocks I’ve seen are threaded for it. If not, I’ve heard they may be drilled but not tapped. Tap the hole if that’s the case.
i read in my old thread that the pilot bearing may be a pain in the arse to get right?
basically I'm wondering what lil POS things I'm gonna run into by swapping this in??
is there any sort of header, intake or any other performance goodies i can throw onto the motor while it is out and being put back together??
the new block is a 96 and the old block is a 87...
thanks for any help guys, its appreciated!!!
Actual headers are a nice upgrade and won't be cracked like 95% of the stock manifolds on 4.0s, put a flex pipe somewhere in the down pipe so your headers don't crack from the rest of the exhaust being "hard mounted". Also a 99XJ intake is horseshoe shaped and supposedly has better flow. I can't say anything because I don't have one. You can also upgrade from the stock injectors to neon/mustang and other 4 way spray pattern injectors around 19 pounds of pressure I believe? Don't quote me on it. While you have everything apart and it's easily accessible replace all the gaskets, seals, water pump and thermostat and I would change the CPS sensor while its easy to get to.
The stock headers crack when the front hanger from the bell housing to the pipe is missing (usually taken off during clutch changes and not put back) then the hanger for the muffler lets go and the whole system becomes a pendulum. Sloppy motor/trans mounts make it even worse.
