gogmorgo Posted December 6, 2013 Share Posted December 6, 2013 If you've got thick rubber soles and your buddy doesn't, or is leaning against the pole, grab the fence and then poke him. Link to comment Share on other sites More sharing options...
redwolf624 Posted December 6, 2013 Author Share Posted December 6, 2013 alright, thanks guys, once i get a chance i'll tackle that bedliner and update yall on it and PFCLeist, try leadin up against a wooden post with an electric fence goin to it for horses, i'll never make that mistake again, have nice thick rubber soles on my boots too, Redwolf Yes, but you did ground yourself as soon as you touched that wooden post, which completed the circuit. Either way, the advice for everyone to take away from this is: Electric fence BAD, haha. indeed it is lol, i think sunday if it's not rainin i'll tackle that bedline, Redwolf Link to comment Share on other sites More sharing options...
redwolf624 Posted December 6, 2013 Author Share Posted December 6, 2013 If you've got thick rubber soles and your buddy doesn't, or is leaning against the pole, grab the fence and then poke him. my buddy did that to his friend one day on the farm lol, Redwolf Link to comment Share on other sites More sharing options...
redwolf624 Posted December 14, 2013 Author Share Posted December 14, 2013 back to the drawin board, i still have high SWRs, i'm replaced the cb radio (the old one stopped workin) and took off the antenna mount to scrap the bed liner off but i still have high SWRs, i get SWRs of 2 on channel 4 but at channel 10 they go sky high again, any ideas? Redwolf Link to comment Share on other sites More sharing options...
redwolf624 Posted December 16, 2013 Author Share Posted December 16, 2013 just a thought, could me backin the ground lead bolted to the antenna mount be a factor of high SWRs to where if i put the ground lead inbetween the mount and the bed would the SWRs go down? Redwolf Link to comment Share on other sites More sharing options...
gogmorgo Posted December 16, 2013 Share Posted December 16, 2013 Are you asking if you should be sandwiching a ground between the bed and the mount, or sticking the ground on the end of the bolt? If so, then that shouldn't matter so long as you're actually grounding through something, although it wound be better to have the eye of a ground lead against a nut or bolt head. You should have had some form of setup instructions that came with your radio or antenna. Did you follow them? If not, you should probably do that. If so, you might want to do some research into what might cause a high swr issue. This might be a good place to start. Link to comment Share on other sites More sharing options...
redwolf624 Posted December 16, 2013 Author Share Posted December 16, 2013 Are you asking if you should be sandwiching a ground between the bed and the mount, or sticking the ground on the end of the bolt? If so, then that shouldn't matter so long as you're actually grounding through something, although it wound be better to have the eye of a ground lead against a nut or bolt head. You should have had some form of setup instructions that came with your radio or antenna. Did you follow them? If not, you should probably do that. If so, you might want to do some research into what might cause a high swr issue. This might be a good place to start. that's exactly what i'm askin, right now i have my ground lead on a screw/bolt, i just wonder if it's cause of the setup i have, i have followed the instrustions, rechecked and rechecked, but still high SWRs, i'm just wonderin if i should get a new coax and a new antenna stud that way it screws onto the stud as aposused to strippin the coax and havin em added to eye terminal leads, Redwolf Link to comment Share on other sites More sharing options...
skel130 Posted December 17, 2013 Share Posted December 17, 2013 Yes. That's my recommendation. I believe your issues are very likely due to the eye terminals. Link to comment Share on other sites More sharing options...
redwolf624 Posted December 17, 2013 Author Share Posted December 17, 2013 Yes. That's my recommendation. I believe your issues are very likely due to the eye terminals. inproper mountin of the eye terminals or havin to file one to make it big enough? Redwolf Link to comment Share on other sites More sharing options...
