Cb Radio And Antenna?
Yes. The link I posted is a replacement stud that will allow you to use the same coax. Technically if you strip the coax and attach the center stud to the ring, it should work, but it's hard to do, and you'll probably create a couple issues.
  • Replies 108
well i'm gonna give it a shot first, i'm havin my dad install everything since he used to deal with CB radios on a daily bases,
Redwolf
ran into a problem, i installed my cb radio, it power one, i hear people on it, don't know if they can hear me (i only have a cobra 19 plus), hooked up the firestik, hooked everything up to a swr meter and my swrs are off the charts, could i have done somethin wrong?
Redwolf
  On 11/25/2013 at 12:57 AM, Oyaji said:
There isn't much you had to do besides hooking up power and antenna. Since it powers up, you should probably start and end with your antenna connections, then.
checked there after askin, noticed that the main wire had snapped, got that fixed now my swrs are higher (if that was possible) tomorrow after huntin when it's sun out i'm gonna try tunin it again, luckly i have the tune top firesticks :)
Redwolf
  On 11/29/2013 at 6:07 PM, skel130 said:
Well you had talked about trying to use the cable ordered by putting a ring terminal on the end. If you didn't get it perfect, then high SWR would be the result.
yeah, i'm thinkin the grounds not the best, once i get my new cb radio i'm gonna try the ground in different spots cause when my girlfriend grabs the antenna the SWRs drop,
Redwolf
played with the ground lead today, got it bolted onto the antenna bracket and i get SWRs of 3 across the channels 1-40 but i can't get the SWRs down to 2 (would like to get em down to 1 or 1.5) any ideas what i should try next?
Redwolf
Back in the day, word was that if there was no antenna load and the mic was keyed the power would "backfeed" into the circuitry and burn something up.
Are CB radios of today overload protected against this, or is it still a potential problem?
it's not a cb radio issue that much i do know, my buddy bought a brand new cobra 29 ltd and let me wire it up in my truck before he did and i still get the same SWRs on that as i do on my cobra 19 plus, so that leads me to believe the antenna area is the issue, could it be that i mounted the antenna mount over top of bed liner? thought of that today at work, but when i power on the cb and grab the antenna the SWRs don't drop,
Redwolf
That is very likely the issue. See if you can get a better ground.
And what Oyaji means is that if you don't get your SWR down, it will burn out your radio. SWR= Standing Wave RATIO. It's a ratio of how much of the power is sent out from the antenna, and how much 'reflects' back into the radio.
And yes, still an issue. :)
ok that makes since, right now i'm waitin untill 12 to take my mj to firestone for an alignment, after that i'll tackle the bed liner,
Redwolf
Only things made of metal will reflect radio waves. If you have a plastic bedliner, it has no effect on the metal beneath reflecting waves and acting as a ground plane.
You should certainly have grounded your antenna though - you didn't by chance mount it to plastic and not to metal, did you? Regardless - you still have a problem, so recheck your antenna connections.
no plastic bedliner, i have the factory spray in bed liner, and there is some of the bedliner under the mount,
Redwolf
  On 12/5/2013 at 6:36 PM, gogmorgo said:
If you're trying to ground through the bedliner, good luck. Rubber doesn't conduct any better than plastic. Everything said still applies.
so there's rubber compounds in bedliner and not just the drop in bedliner?
Redwolf
Heh heh, funny story about rubber. If you've got thick rubber soles on your boots, go grab an electric fence. You won't get shocked because of how well rubber insulates. Put your knee on the ground and get ready for one hell of a jolt! Don't ask me how I know. But yes, rubber is a BAD conductor, I'd sand it down to metal.
alright, thanks guys, once i get a chance i'll tackle that bedliner and update yall on it and PFCLeist, try leadin up against a wooden post with an electric fence goin to it for horses, i'll never make that mistake again, have nice thick rubber soles on my boots too,
Redwolf
Redwolf
Yes, but you did ground yourself as soon as you touched that wooden post, which completed the circuit. Either way, the advice for everyone to take away from this is: Electric fence BAD, haha.
