Wiring for horn
Been working nights here, I went out and looked for the relay to no avail, any sugestions besidesget more than 2 hours of sleep before I try to make sense of anything? Where are the !@#$%^ relays????? Sorry I am kinda punchy... :D
GOT IT :!: OK it wasn't the relay, horn or an open in the circut. The steering wheel had developed a strange powder like substance on it, some may call this odd chemical reaction rust. After I cleaned it it works perfectly.....DOH!
  CWLONGSHOT said:
SORRY for the hijack...
Any body have a fix for the dead spots in the horn as I turn the wheel?????
CW
sounds like your slip ring is tarnished or corroded. You'll have to take th steering wheel apart and get at it. Either clean it up, or replace the ring and the wiper arm. Autozone will rent you the spring compressor and wheel puller.
