DirtyComanche Posted April 14, 2007 Author Share Posted April 14, 2007 I really like it. just wet sand the runs and defects, and respray 1 last coat and there you go. I think it's a little too bad for that. But maybe I'll try it. What grit should you be using for that? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 14, 2007 Share Posted April 14, 2007 not sure what grit...that's a ??? for someone else. I'd say something between medium and fine but no clue what exact... just not course cause you don't want gouges, just smoothness. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 14, 2007 Share Posted April 14, 2007 Dirty, NICE color!! I really like it. Its very close to what I will use. I am going to try to match a early '90's, Dodge PT Crusier color. I think it is called ELECTRIC BLUE. Anyway its quite close to your blue. Nice write up BTW. Keep it up!! :popcorn: CW Link to comment Share on other sites More sharing options...
sinnaevd Posted April 14, 2007 Share Posted April 14, 2007 i would use something pretty high, like in the 600's prolly. use soap and water, get it nice a greasy and have at it. say away from ur body lines as you will cut righ threw them. use the razor on the runs before you wet sand. wash it all down with water when ur done and shoot a nice light coat over it. should turn out a lot better for u if ur spraying in the garage again, wet ur floor to trap the dust, and pull it out of the air. it will give u better results. Link to comment Share on other sites More sharing options...
