Kkilmer87 Posted September 12, 2013 Share Posted September 12, 2013 Hey guys my gauge and cable and gear all work when I take it out of the ax15 2wd housing and manually spin it but when I put it back in = no work.....??? Can anyone help PO sold me a pos lol Link to comment Share on other sites More sharing options...
AeroNautical Posted September 12, 2013 Share Posted September 12, 2013 I had a similar problem with mine. When you put it into the tranny, it pushes the speedo shaft inward, and adds slack to the instrument cluster side. I fixed it by taking the cluster out and pushing that end of the speedo shaft in a bit to give more slack on the tranny side, plug it into the tranny making sure it doesn't push.... you know what? This'll fix it, but it's so much easier to just buy a new speedo or get one from a junkyard. Long story short: your right, PO sold you a crap speedo cable. Link to comment Share on other sites More sharing options...
Eagle Posted September 12, 2013 Share Posted September 12, 2013 Are you aware that the "quill" that holds the speedo drive gear -- the piece that you bolt into the transfer case -- has to be oriented properly depending on the number of teeth on the speedo drive gear or it won't work? You can't just bolt it in and assume it's right. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 13, 2013 Share Posted September 13, 2013 http://gojeep.willyshotrod.com/HowtoSpeedoGears.htm Link to comment Share on other sites More sharing options...
Kkilmer87 Posted September 13, 2013 Author Share Posted September 13, 2013 Okay thanks eagle it's actuall on your old 89 2wd frankthedog told me you used to own it i bought it off some guy and gave it a little refresh and just sold it ..... Link to comment Share on other sites More sharing options...
