mdwatson Posted September 10, 2013 Share Posted September 10, 2013 My oil pan is leaking at the front and was wondering what the best gasket to use when I replace it. Link to comment Share on other sites More sharing options...
Comanchemodder Posted September 10, 2013 Share Posted September 10, 2013 I bought the one-piece from a '94+ YJ. It needs a little RTV in the corners but otherwise was really easy. Note: This was for a 2.5L and '94 motor. I assume the one-piece will work for older 2.5L, but I would ask an expert to confirm. Not sure what year your engine is. Link to comment Share on other sites More sharing options...
87Warrior Posted September 10, 2013 Share Posted September 10, 2013 I put the gray one piece gasket in my 86 2.5. A little RTV around it and she hasn't leaked at all. Link to comment Share on other sites More sharing options...
mdwatson Posted September 10, 2013 Author Share Posted September 10, 2013 Forgot to mention it's a 86. Hey 87Warrior, do you happen to remember the part # on the gasket? I've only been able to find the multi piece ones. Link to comment Share on other sites More sharing options...
87Warrior Posted September 11, 2013 Share Posted September 11, 2013 Crown Automotive #4713021 http://www.jeep4x4center.com/oil-pan-gasket-set-4713021.html The fit was pretty loose, but works well with some RTV on each side. Link to comment Share on other sites More sharing options...
huck731 Posted September 11, 2013 Share Posted September 11, 2013 I just put a multipeice fel-pro on adn I put some rtv on the help hold it it place, went on real nice. Link to comment Share on other sites More sharing options...
