Project Smoky
So I have finally decided to start a build tread, So this is the one of the oldest photos i could find of my MJ. The only thing I had done to it since I bought it was
1- rattle can the rims black
2- remove the old pioneer decal
3- remove the old camper shell
4- added the old plactic tool box I had
So after the suspension lift I tried to get an inspection of course it failed my luck had sucked so far on the truck. :fs1:  :fs2:  :soap box:  :mad:
It failed for a exhaust leak, brake booster and rear proportioning valve leaking as well
I found the exhaust leak :mad:
so I replaced the exhaust manifold
the brake booster and master cylinder was leak where they met
