louie130309 Posted January 20, 2006 Share Posted January 20, 2006 So i got a real good deal on some 31x10.5 bf goodrich a/t, and i was just wondering if anybody has any expierience with 31's and no lift. I plan on cutting the fenders, is there anything else to make a little bit of room. I'm lifting it about 3 inches soon, but i was just wondering if they will fit now? thanks Link to comment Share on other sites More sharing options...
pingpong Posted January 21, 2006 Share Posted January 21, 2006 They shouldfit, expect some minor rubbing on your LCA's Link to comment Share on other sites More sharing options...
Eagle Posted January 21, 2006 Share Posted January 21, 2006 They shouldfit, expect some minor rubbing on your LCA's They WILL fit. No cutting necessary if you run stock Jeep rims. There will be slight rubbing on the lower control arms at full steering lock Link to comment Share on other sites More sharing options...
louie130309 Posted January 21, 2006 Author Share Posted January 21, 2006 yea i am going to run them on the stock rims. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted January 22, 2006 Share Posted January 22, 2006 Why not just do a quick and easy buget boost? Pick up some 2" spacers and longer shackles. It'll look better and fit better too!! As stated, most MJ's can run 31"s OK some not as well. It sll depends on spring sag and if ou articulate too much. Likely it will contact the lower control arms near full lock. CW Link to comment Share on other sites More sharing options...
pingpong Posted January 22, 2006 Share Posted January 22, 2006 Eagle, I agree the "will" fit, but I try not to make those judgements with out first seeing the vehicle in person. I don't want to be the one responsible for ppl buying il fitting parts. Patrick Link to comment Share on other sites More sharing options...
louie130309 Posted January 23, 2006 Author Share Posted January 23, 2006 i am actually getting the tires from my brother in law for free, he is tading his truck in and i'm switching mine with his. I am going to be running a 3 inch lift soon, i just wanted to make sure the tires would fit ok now. Link to comment Share on other sites More sharing options...
