onlyinajeep726 Posted August 24, 2013 Posted August 24, 2013 I have for sale a working Jeep engine, transmission, 4WD transfer case, computer/ECU and wiring harnesses pulled from my '86 Comanche MJ Pickup. It started and ran great before I removed it from the truck. I'm swapping in a bigger engine and am no longer in need of this drivetrain. Included in this sale are the following: - AMC/Jeep 2.5L Inline 4 150ci engine, complete with accessories, every sensor and wiring harness intact and labeled for easy reinstallation - AX4 4 speed manual transmission with working clutch and slave cylinder, shifts great - NP207 "Command-Trac" 4WD transfer case - Original, all copper radiator with cap - Engine wiring harness and interior dash harness, fuse panel and so on - Renix Engine Control Unit (ECU)/Computer - Starter - Battery cables and clamps There are lots of goodies on this engine, including a brand new TPS sensor, brand new spark plugs, aluminum valve cover (swapped on from a newer 2.5L Cherokee), etc. For everything included, this is a steal. This will bolt right into another Jeep Comanche MJ, Jeep Cherokee XJ or Jeep Wrangler YJ. One of the most reliable engines Jeep ever put into their vehicles, right along side the Inline 6 4.0L. Here's a quick video showing the engine running the night I started the removal. Idles steady at about 850-900 rpm. Craigslist ad link: http://raleigh.craigslist.org/pts/4022037370.html
Archived
