I have an 88 MJ that the steering column is Fu****. I have a 2001 XJ column to put in. I need a list of what wire does what in the MJ going up to the steering column, and a list of the same on the 2001 XJ column. New coulmn only has key, turn signals (with brights), and wiper speed and spray on the other side, and hazard. I know I won't need half of the wires, question is which ones do I need? In the plug coming off of the key, I applied power to the red one, and there is power going through the black and white wire, and the blue wire. Turning the key to start gives me power to the yellow, so I know what I will do with those. I need to figure out how to apply power to the turn signals and the wiper switch, but the wire combos I have tried haven't worked thus far. here's pics:
Disabling the airbag:
And the red, yellow, back and white, and blue:
Ignition:
Wiper switch:
Turn signals:
Mystery plug:
The whole shebang and my test setup:
