weishouse Posted August 20, 2013 Share Posted August 20, 2013 I have an '88 comanche with the ba10/5 trans. When the outside temp. is approx. 40 deg. or lower, the speedometer reads way faster than the actual road speed when going approx.10 mph or faster,and there is a whining noise that seems to be coming from the speedo cable and/or the speedo output gear in the trans.When slowing down below 10 mph,the noise stops,and the speedo reads correctly.I have filled the trans. with the correct grade & weight of gear oil. When it is warm outside, it works great.Has anyone else experienced this?Any ideas on what causes this and/or how to correct it would be greatly appriciated! Thanks. Link to comment Share on other sites More sharing options...
Eagle Posted August 20, 2013 Share Posted August 20, 2013 I'd say the speedo cable needs to be lubricated. Link to comment Share on other sites More sharing options...
yxmj Posted August 20, 2013 Share Posted August 20, 2013 I'd say the speedo cable needs to be lubricated. X2 I had the same noise (my MJ had sat for 10 years) I used an white lithium grease that came in an aerosol can with a straw ( I think from the factory it is a graphite based lube)......undid the cable..... shot as much as i could in.....put it back on and drove for a couple of days and repeated the process. I did it from the bottom....i would expect that if you took the time to pull the dash and get at the speedo from the top gravity would help you pull in even more lubricant and speed up the process. :thumbsup: Link to comment Share on other sites More sharing options...
weishouse Posted August 21, 2013 Author Share Posted August 21, 2013 thanks,Eagle and yxmj,for taking the time to respond to my post,and for your helpful information. :) Link to comment Share on other sites More sharing options...
