'94 2.5L Fuel Pressure Specs
Hi guys,
Current rig:  '87 2.5L 2WD, AX4, Renix
Looking to swap to '94 2.5L
The current engine leaks oil like the exxon valdez.  I bought a newer 2.5L which the PO indicated was from a '94 YJ (but I did not verify).  I am prepping for the swap and one question is the fuel needs.  The new engine has port fuel injection whereas my Renix has the TB. My plan is to swap in the new ECU and accessories from the '94 and ditching the Renix.
Will I need to swap the fuel pump and/or pressure regulator?  If yes, are there other components in the fuel system which need swapping due to the higher pressure (filter, lines, etc).
You would need to swap every bit of wiring in the truck.... and everything else from a 91+ 2.5 XJ/MJ.  Just bolt your TBI system to the new motor, and you should be golden.
You may need to swap some sensors over from your old motor.
