JT31 Posted August 7, 2013 Share Posted August 7, 2013 so my mj runs good when its cold but once it gets warmed up it idles funny, the idle fluxuates a lot, and it also smells like I'm running very rich, i tried replacing one of the air monitors on the vacum system and even replaced my cat and muffler, only thing i can think of is the injectors maybe i have a stuck injector? its an 87 with the renix with 225,xxx miles any thoughts? p.s i once burned a 1/4 tank of gas just idling for 45 mins Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 7, 2013 Share Posted August 7, 2013 Replace your O2 sensor. Link to comment Share on other sites More sharing options...
JT31 Posted August 7, 2013 Author Share Posted August 7, 2013 Replace your O2 sensor. I don't have an 02 sensor Link to comment Share on other sites More sharing options...
cruiser54 Posted August 7, 2013 Share Posted August 7, 2013 Sure does. If not, you will have high fuel consumption and idle issues..... Link to comment Share on other sites More sharing options...
JT31 Posted August 8, 2013 Author Share Posted August 8, 2013 found the plug for the 02 sensor, but no 02 sensor :hmm: , guess i should put one in haha :yes: Link to comment Share on other sites More sharing options...
cruiser54 Posted August 8, 2013 Share Posted August 8, 2013 found the plug for the 02 sensor, but no 02 sensor :hmm: , guess i should put one in haha :yes: Yeah. Probably. Is the hole in the manifold plugged with something like an old spark plug? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 8, 2013 Share Posted August 8, 2013 found the plug for the 02 sensor, but no 02 sensor :hmm: , guess i should put one in haha :yes: Where did you find the plug? On the exhaust manifold? Or elsewhere? Also, did you locate the 3-pin harness connector that the O2 sensor plugs into? Link to comment Share on other sites More sharing options...
