aquiring93 Posted August 6, 2013 Share Posted August 6, 2013 I'm looking to make the doors on my 'manche easily removable. I was wondering if y'all had any tips on the best way to do this. Thanks for the help y'all. Link to comment Share on other sites More sharing options...
johnnyc Posted August 6, 2013 Share Posted August 6, 2013 Cut the hinges like this. Then you'll be able to lift the doors off. Link to comment Share on other sites More sharing options...
aquiring93 Posted August 6, 2013 Author Share Posted August 6, 2013 So basically just cut the bottom portion of the hinge off? That simple? How easily does it lift off? Link to comment Share on other sites More sharing options...
johnnyc Posted August 6, 2013 Share Posted August 6, 2013 Lifts off easily with one person. Better to have two people though. Link to comment Share on other sites More sharing options...
gregz0r Posted August 12, 2013 Share Posted August 12, 2013 The drivers door is easier to do than the passenger. With the drivers door the hinge pin is pressed in from the top of the hinge while on the passenger side it's pressed in from the bottom. When I did mine I just pressed the pin out of the section I cut on the passenger side and pressed it in from the top to match the drivers side. After 4 years of wheeling I still have yet to see any sagging at the hinges. Best mod you can do for the money IMO. Link to comment Share on other sites More sharing options...
