jeepmarine312 Posted July 26, 2013 Author Share Posted July 26, 2013 i replaced the bottle and it runs way better, no more coolant dump. well bottle and cap, found a good one at the JY, great condition. it only overheated after i added the thermostat. before that i had no problems whatsoever. drove to hilton head, SC and back from Grovetown, GA. and she went fine the whole time. Modern automobiles NEED a thermostat to run properly. Many people simply don't understand that the purpose of the thermostat is to keep the temperature UP, not down. A properly-functioning radiator and cooling system are capable of keeping the temperature well below the temperature needed for optimum combustion -- in fact, often below the minimum temperature for the electronics to switch over to to closed loop operation, meaning the system is reading and reacting to all sensor inputs. For the Renix-vintage Jeeps, that switch-over takes place at somewhere between 170 and 180 degrees F (I used to know more exactly, but I haven't thought about it for a long time). Removing the thermostat could have you running in open loop mode all the time. The vehicle will run ... but it will be always running on a pre-mapped air/fuel curve that's far richer than optimum for an engine at normal operating temperature, and the fuel mileage will suck. Removing the thermostat is NOT a fix -- it's a temporary bandaid that just masks the symptoms of an underlying problem. my fuel milage is amazing... like for real, its better then my buddys 4 cyl ranger... Link to comment Share on other sites More sharing options...
cruiser54 Posted July 26, 2013 Share Posted July 26, 2013 Imagine that.... Get the Napa cap just as a precaution when you get a chance. Link to comment Share on other sites More sharing options...
jeepmarine312 Posted July 26, 2013 Author Share Posted July 26, 2013 ill try and do that soon, but as for now I'm just happy to have a running vehicle again. Link to comment Share on other sites More sharing options...
