Gas Milage Problem
Going from "E" on the gauge isn't reliable enough to determine a true empty tank.  You'll always have some in the tank when filling up, even from "E".  6 gallons worth?  That I don't know for sure.  I've heard multiple times that the low fuel light comes on when you have ~2 gallons left.  If I'm not mistaken, it says that in the owner's manual also.
i'll read the manual tomorrow, i bought a 2x4 one off ebay but never fully read it, i don't even think my low fuel light works bein that i used to have a mechanical fuel pump mounted to the side of the engine block,
Redwolf
I can attest personally...and ONLY in my MJ, that when the light goes on telling me I'm almost out of gas, I still have almost 4 gallons in the tank.
My XJ only has ~ 2.5 gallons in the tank when the light goes on.  Basically the same sending unit (basically), but it's placed in a different spot on the tank (and on the truck) and varies depending on the way it's parked (up or down, right slope, left slope or level).  Not an exact science.
that is true, all i know is that my light don't come on, i don't know if the bulb is burnt or if i don't get the light cause i don't have a computer,
Redwolf
