dakal Posted March 31, 2007 Share Posted March 31, 2007 since i bought this jeep three mos ago, all i've done to the motor is spark plugs, and magnacor wires. then i pulled the air cleaner off, and stickie and gummie it was. checked the tps and idle control , same mess. cleaned well and mpg went to middle 14s. but my mileage has been in the middle 14 's- so i found out the oxygen sensor was shorting so it was in closed loop all the time. someone broke the pin for the temperature sensor so i replaced that also. my idle went to 1500, so i adjusted it to 850. everything helped, but stepping on the gas accelleration was bad. so i took the exhaust system off and looked in the cat. hooray for big pry bars. put it all back , what a difference. idle speed was bouncing around before i did the cat, but after driving few miles, stopping and cooling it down, started it up idle was great. between here and naxja forums, i learned a lot. had no experience with i-6. i'm going to check the tps voltages and adjust if necessary. i have the cracked exhaust, must fix{ $} going to drive it on the freeway 75 mph for fifty miles to clean it out, then i'll check mileage and live with it. anyway, i had no idea that cleaning out the cat would make such a big difference. :brows: Link to comment Share on other sites More sharing options...
jared Posted March 31, 2007 Share Posted March 31, 2007 don't expect good mileage from the 4.0, but they have good torque. this guy has a site page about them. http://www.jeep4.0performance.4mg.com/ Link to comment Share on other sites More sharing options...
Pete M Posted March 31, 2007 Share Posted March 31, 2007 A good cat won't affect anything, but a bad cat will choke the life out of an engine. Link to comment Share on other sites More sharing options...
dakal Posted March 31, 2007 Author Share Posted March 31, 2007 ya i know dino's site, thanks, also go jeep is good. eagle- i went to gibsons site and listened to the muffler. good sound. when i replace cracked exhaust i'll change pipe and muffler with their's. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 31, 2007 Share Posted March 31, 2007 Amazing it wasn't running hot with a clogged cat. Mine did on the old engine (after I replaced virtually everything in the cooling system). The cat was clogged at the inlet with thick gummy tar-looking crap. Put in a new stainless aftermarket cat and replaced the O2 sensor for the cure. Link to comment Share on other sites More sharing options...
