Rough Country Drop Brackts
Just installed control arm drop brackets. The reason I did was the front passenger side bump stop was hitting coil. They are rough country 4 1/2 coils with rough country fixed lower arms. After installing the front drivers side coil is hitting sway bar link. So why is passenger bump stop in middle of coil  and drivers side bump stop not in middle of coil and hitting sway bar link.thanks
The drop brackets are causing the fixed length control arms to push the axle forward. With drop brackets and 4 1/2 arms u can run 6 inch springs. So answer arms are to long. And do u have a track bar for lift or oem?
