was driving and my battery slipped into my alternator fan and shredded it spewing acid everywhere engine stalled and ever sense it won't start it gets spark and fuel but it won't even fire on starting fluid tried pull starting it to as i was getting towed home by a buddy fml... could it be cps or tps???
CPS generates it's own signal. Should be fine. TPS won't keep it from starting. What about the coil/ICU right near the battery?
Never drive with a battery not fastened down...........
thanks it fried the ignition coil i washed it all out and put baking soda on everything to nutralize the acid. just picked up a msd blaster and now it runs like a dream. battary was strapped down but it turns out the battary box is broken at the mounts.....
