86 Gas Tank
Truck is an 86 2.8/ax5/4x4
My truck has an electric fuel pump, and every so often, the pump would stop pulling fuel. Figured there was crap in the tank that was clogging the line, so i pulled the tank, pulled the sending unit, and this is what i've found
Inside the tank. The black "x" is where the in tank filter sits
The sending unit
And bottom of the filter
At this point, given the cleanliness and rust-free insides of the tank, I'm thinking it was a bad vent caused by rotten hoses that wasnt allowing the pump to pull more fuel from the tank, but since its off I want an opinion on the sending unit itself, if theres anything i can check, replace the filter, etc so i don't have to pull the tank again anytime soon
