Yes, as long as that 242 came from behind the same transmission. Transfer cases have different input shafts depending on what transmission they came behind, possibilities are 21 spline and 23 spline, and three different lengths for both of those.
If the 242 is from before 1994, you *might* be able to swap the 231 input shafts into it, but I have never verified this.
You will also need the shift gate and long linkage rod from the 242.
