Bmoore2 Posted April 1, 2013 Share Posted April 1, 2013 Hey guys, When I got my shocks the rear shocks (Bilstein 5100) they have a cross pin with 2 holes. My mounts look like I need just a hole. Do I have the wrong shocks or is there a "mount" that I should have. I searched the forums and the internet and it looked like people were having to punch that end out. I really didnt like the sound of that. Big thanks for any info pals! Link to comment Share on other sites More sharing options...
jimoshel Posted April 1, 2013 Share Posted April 1, 2013 Sounds like the wrong shock. There is a mounting pin on the spring mount and the frame. The shock fits over these mounting pins so there should only be one hole on each end of the shock. Link to comment Share on other sites More sharing options...
dakal Posted April 1, 2013 Share Posted April 1, 2013 in the front on the bottom you need the cross pin. i did. in the back its regular holes for the bolt. i have 5150's. dave they are great shocks. i've used both. if you don't need the pin, just pull it. Link to comment Share on other sites More sharing options...
Bmoore2 Posted April 1, 2013 Author Share Posted April 1, 2013 in the front on the bottom you need the cross pin. i did. in the back its regular holes for the bolt. i have 5150's. dave they are great shocks. i've used both. if you don't need the pin, just pull it. I don't want to damage the bushing or void my warrenty trying to pull the pin out as it flat on the ends with holes for it to bolt up. Waiting on Kolak to call me back and see what "Mr. Salesman" has to say. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 1, 2013 Share Posted April 1, 2013 What is the Bilstein shock number you are referring to? Front or rear? Link to comment Share on other sites More sharing options...
Bmoore2 Posted April 1, 2013 Author Share Posted April 1, 2013 What is the Bilstein shock number you are referring to? Front or rear? Its the rear shock.... I don't have the exact part number because my invoice just says Bilstein Shock for Jeep 6 inch lift. This is exactly what it looks like. 46mm Monotube Shock Absorber (click for more info) Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 1, 2013 Share Posted April 1, 2013 That's a ZJ or XJ rear shock. The part number should be stamped on the shock body. If the travel is right, you can press the top bar pin out and use it for the MJ top eye mount. Link to comment Share on other sites More sharing options...
Bmoore2 Posted April 1, 2013 Author Share Posted April 1, 2013 That's a ZJ or XJ rear shock. The part number should be stamped on the shock body. If the travel is right, you can press the top bar pin out and use it for the MJ top eye mount. I am at work currently and don't have access to the shock. Sorry about that. The front ones fit perfectly. I was just worried about tearing up the bushing pushing the pin out since its kinda wide on the ends. . Link to comment Share on other sites More sharing options...
Bmoore2 Posted April 1, 2013 Author Share Posted April 1, 2013 Lube it up and pull the pin is what the salesman told me to do. If we tear up the bushing its a standard 5/8 bushing. Link to comment Share on other sites More sharing options...
