hey i got a good leak in my intake manifold gasket at between piston #5-6 and it makes a wine sound like got a blower, is this a problem i need to fix or will it be fine (i like it a little)
Thread jack, but that'll cause a big vacuum leak. I've got it now and my sensors and brakes hate me.
I will be installing a glasspack on mine shortly, as soon as I get a short section of pipe bent to keep the exhaust in line with the rear hangers (to make up for the offset outlet on the OEM muffler). I'm going to run a short piece of pipe out the back to just past the rear hanger and then a turndown tip before the axle.
If it sounds like @$$, I'll put another dynomax on it.
Jeff
I can tell you from my '88 2.5, with the cat and a glasspack on it, prepared to be disappointed with the sound, unless you like the semi-ricey sounding exhaust. Mine sounds like a swarm of angry hornets chasing me. I have the glasspack welded to the cat and about a foot to a foot and a half of pipe after it.
