motor questions
I just "jury rigged" mine.
I get 10-12 mpg turning 33s on stock gears with the HO injectors.
I clogged my cat (and killed my tranny) from running rich, not sure if it was the TPS or injectors fault. If I had it to do again I'd try the adaptor.
well this is a trail truck so i don't care about mpg and emissions..etc i just want it to turn on and get up rocks haha ill prolly cut off the cat, and run just a muffler
so iam gonna "jurry rig" it
If you have a 5-speed like your sig says, then I don't think you'll even have to jury-rig it, that TPS is just for automatics, your TPS looks different I think. If this is your TPS, you're good to go:
http://www.rockmodified.com/offroad/Tech/TB/tb_perf.htm
Make sure you run SOMETHING to get the exhaust away from the cab if you're running rich, my exhaust ripped off (again) and on my last wheeling trip when I got out of the XJ I was high as a kite from the fumes & had a pounding headache...
