timberjack Posted March 24, 2013 Share Posted March 24, 2013 I have a 89 Comanche and the heater blowes hot for about 10 sec then turns cold. Turn the fan off and it takes about 5 min to get hot again so turn blower back on and same thing. So what am i doing wrong. I made sure the cable driven flow valve was open too. Heater hoses are also not hot going into the heater core.???? Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted March 24, 2013 Share Posted March 24, 2013 http://www.cherokeeforum.com/f51/dash-removal-35444/ About 3/4 of the way down in this writeup you will find what controls your "blend" door, this is the door that diverts air either to be pulled through the a/c or the heater core. If the diaphram stops working or startings leaking it will only hold the door open for a moment until the vacuum is not strong enough. If it were my truck this is what i would be looking at and yes you have to pull the dash. hopefully someone else will chime in to verify. Link to comment Share on other sites More sharing options...
Eagle Posted March 24, 2013 Share Posted March 24, 2013 If the hoses leading to and from the heater core don't get hot with the vaccuum valve open and the engine at normal operating temperature, the only answer is that there's no coolant flowing through the heater core. Let's face it, it's 24 years old and probably plugged solid. I kept the heater core on my '88 Cherokee flushed out, and it sprung a leak three years ago. I just blocked it off and ran without a heater for one winter, then I replaced the heater core. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted March 24, 2013 Share Posted March 24, 2013 Oh ya, forgot about the vacuum do-hicky, i got rid of mine so long ago i forgot about it :D . This thing. . . Link to comment Share on other sites More sharing options...
timberjack Posted March 24, 2013 Author Share Posted March 24, 2013 Ok thanks all it is about winter over here in Missouri so will check this all out. Link to comment Share on other sites More sharing options...
