54bobby Posted February 26, 2013 Share Posted February 26, 2013 so, as a shade tree machanic, what am i getting myself into changing the exhaust mani and front pipe on my 87 2.5? i will mention that 2 mani bolts will have to be easy outed cause the heads are off. should i just pay someone to do it? how many hours? Link to comment Share on other sites More sharing options...
comanche1989 Posted February 26, 2013 Share Posted February 26, 2013 Never use easy outs. If they break you're in big trouble. Are you talking about the two bolts that connect the manifold to the downpipe? You should be able to grind them flat then drill them out.The exhaust manifold is fairly easy to replace, but somewhat time consuming. Get yourself a Chiltons and it should be able to completely explain the whole process. Make sure to spray all bolts with a penetrating catalyst like pb blaster a couple times before attempting to remove bolts! :thumbsup: Link to comment Share on other sites More sharing options...
54bobby Posted February 26, 2013 Author Share Posted February 26, 2013 Never use easy outs. If they break you're in big trouble. Are you talking about the two bolts that connect the manifold to the downpipe? You should be able to grind them flat then drill them out.The exhaust manifold is fairly easy to replace, but somewhat time consuming. Get yourself a Chiltons and it should be able to completely explain the whole process. Make sure to spray all bolts with a penetrating catalyst like pb blaster a couple times before attempting to remove bolts! :thumbsup: the broken bolt heads are to the head. how do i get them out if not useing easy out? i have a hayes repair manual. will that work or is the chilton that much better? Link to comment Share on other sites More sharing options...
comanche1989 Posted February 26, 2013 Share Posted February 26, 2013 If the bolt heads are completely broken off, you can still remove the the manifold. Then it might be possible after a few days of soaking in pb blaster to put a big pair of vice grips on them and remove them. As long as the threads aren't stripped buy new bolts and you should be okay! If you are unable to remove them with vice grips, I would suggest removing the head and either buy a new or used head or bring the head to a machine shop to get the bolts drilled out. Link to comment Share on other sites More sharing options...
Htchevyii Posted February 27, 2013 Share Posted February 27, 2013 I have had good luck welding a nut to broken off bolts, (weld thru the inside of the nut). Link to comment Share on other sites More sharing options...
