Hello everyone, I have a question. I have an 87 Comanche 2wd ax4 2.5l. runs great just needs 4wd! I have another Comanche I'm able to get at a pretty good price, but it has a 6cyl 4x4 and it smokes alot. my question is will the transmission and transfer case bolt up to my jeeps Engine?
The other trans is a ax-5 if I'm not mistaken. It's an 88 or 89 model. So they will not swap. Okay that's all I needed to know then! Thanks!
No. That works with the AW-4. AX-5 and AX-15 are completely different in that regard.
An AX-15 can be mounted behind a 2.5 with a certain year range Dakota 2.5/5 speed bellhousing, but they're insanely hard to find.
