Need Some Advice On Leaking Brakes
  On 2/22/2013 at 4:42 PM, 1987manche4x4 said:
Actually I take that back I almost forgot. The little rubber end on the cylinder piped off when I was bleeding my brakes. That's we're it leaks from.
How could it pop off?
First off, the rubber cap you can see is only a dust cap. The actual gland/seal is inside the cylinder. There are two, one facing front and one facing rear. Then there are two metal (or sometimes plastic or ceramic, I guess, but I'm ancient and I've only seen metal) pistons, then the rubber dust boots. If you have a pre-1990 MJ with Bendix drums, there should be short connectors that extend from the metal pistons to the front and rear shoes. If you have a 1990+ with 9" Chrysler brakes, the shoes contact the pistons directly.
http://constructionforklifts.tpub.com/TM-10-3930-621-34/TM-10-3930-621-340128im.jpg
With a bleeder screw open, you just can't generate enough pressure to pop anything.
Please tell me you weren't bleeding the brakes before you reinstalled the brake drums ...
We had the drums on and when we bled them we saw it dumping fluid and were like wtf so we took the drum off and it was leaking out of the new cylinder . I just can't figure out why it would be leaking
A very long time ago I needed to do a brake job before heading off for a weekend to pick up my then-fiancee in another state and from there trek over some mountains to visit her grandparents. To get it done, my brother came over and, while I did one side he did the other side. Cool, bro, thanks a million.
As we started down the back side of the mountains, the brake warning light came on and the peddle dropped. Oh, bleep. Fortunately, the car was a manual transmission with a high compression V8 so there was plenty of compression braking available and we made it fine with only the front (disc) brakes. After I returned home from the weekend, I pulled the rear brakes apart to see what might have gone wrong.
What went wrong was that my helpful brother wasn't as careful working on my car as I know he would have been on HIS car. He assembled on of the link bars between the piston and the brake shoe wrong, and it came off under pressure. Once the link was gone, there was nothing holding the pistol in the wheel cylinder, so it popped out. The parts were there and I was able to reassemble the wheel cylinder, but the fluid had ruined the brand new brake shoes on that side. And, of course, they don't sell brake shoes for just one side, so ...
That was, IIRC, 1973. In the forty years since, I have never allowed anyone but me to work on my brakes.
But I digress. The point of this shaggy dog story is simply that it is possible to put things together wrong, allowing a wheel cylinder to pop. Double check how everything fits together.
