Comanche_Fanatic Posted February 21, 2013 Share Posted February 21, 2013 Ive got a '86 MJ XLS 4x4 and the chevy motor and auto trans in it is a POS, I need to change out both of them and put in a reliable Inline motor (2.5L, 4.0L, or 4.2L ) along with a 5spd manual trans and the clutch system as well. It has to be 4x4 compatiable cause I don't have the long driveshaft. If you have what I'm looking for let me know ASAP, thanks. P.S. I'm in the Middle Georgia area. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted February 22, 2013 Share Posted February 22, 2013 Just going to give you a heads up... If you a do a 4.0L swap, you're going to have to make some modifications to the front frame support and radiator mounts to make room for the larger engine. It's a swap I'm looking to eventually do if my 2.5L craps out. That, or a Cummins 4bt hahaha. But seriously, AMC changed the engine bay a little to house the I6. If you're okay with swapping a 2.5L, your current radiator will work find and you can use an AX4 or 5 transmission. Either way, you're looking at a wire harness swap and all the controls to go with it. I wish you lived closer, I'd love to help. Link to comment Share on other sites More sharing options...
Comanche_Fanatic Posted February 22, 2013 Author Share Posted February 22, 2013 Yes I'm aware of all the mods needed to do the swap. I'm more concerned with the exhaust system really, cause its going to be different from stock. I hope i get a 4.0, but a 2.5 works fine, theyre strong motors still. Not many 4x4 manuals left out there. Hope i find one soon, 2 cylinders on the 2.8 are toast n its running on 4 now. Link to comment Share on other sites More sharing options...
1989MJ Posted February 24, 2013 Share Posted February 24, 2013 I've got a 86 model Comanche 2.5 5-speed 4x4 motor complete minus power steering pump and bracket runs but has water in oil still in truck. 5-speed also needs some work 1st and 2nd are out. I will sell you whole truck with title for $800 missing tailgate, taillights, wheels/tires, steering column, and bench seat. Located in Bryson City, NC Link to comment Share on other sites More sharing options...
