Jag 4.0 swap
Having seen my dad under the hood of our jag and cussing to high heaven you might just want to go the normal stroker route on the jeep 4.0. If you get your hands on a jag engine for free, sale it quick it should more than pay for performance mods.
I don't know anything at all about the Jag motor, but being that it is used in cars only, check out the torque curve on it, and see what the possibilties of getting a 4wd tranny or divorced t-case are. Also, check on weight. Aluminum block and head'd be pretty trick.
torque curve is easily solved with lower gears.
Seeing as Jag is now part of ford I bet you could find a 4WD application for that motor, or it shares a BH bolt pattern with something. They don't make motors for just one automobile anymore.
