bluzmj Posted January 20, 2013 Share Posted January 20, 2013 Wife an I made a trip to Davey's Jeep and picked a 89 comanche 2wd 2.5 5speed does not run home and in the garage are plans is to tranzs plate the drive tran from this one 4.0 auto 4wd also to use HP 30 with 3.5 coils & spacers with a 44 from the parts comanche and do a SOA Link to comment Share on other sites More sharing options...
bluzmj Posted January 20, 2013 Author Share Posted January 20, 2013 I manage to pull the 2.5 5 speed and started on the 4.0 Link to comment Share on other sites More sharing options...
bluzmj Posted January 26, 2013 Author Share Posted January 26, 2013 I manage to pull the 4.0 and auto out of the donor from the scrapmanche. switch out the front bumper and tow hooks. pulled some of the wiring harness from the 2.5 to make room for the 4.0 still have a lot to do, any advice on this build will help. Link to comment Share on other sites More sharing options...
86customanche Posted January 27, 2013 Share Posted January 27, 2013 What's wrong with the said scrapmanche? Link to comment Share on other sites More sharing options...
bluzmj Posted January 27, 2013 Author Share Posted January 27, 2013 What's wrong with the said scrapmanche? everything under it is rusted away floors,rockers, bed sides from the in side out. and it;s only has 64000. miles on it. the one we picked up from Davey's has a solid body. Link to comment Share on other sites More sharing options...
bluzmj Posted January 31, 2013 Author Share Posted January 31, 2013 been work on changing out the dashes and heater boxes past couple days.I ran into this evening the heater / ac box that I want to use is busted.I'm going to change the two boxes out. if it possable. Link to comment Share on other sites More sharing options...
bluzmj Posted August 21, 2013 Author Share Posted August 21, 2013 man I need to up date this Link to comment Share on other sites More sharing options...
jbain Posted August 21, 2013 Share Posted August 21, 2013 Hey craig I posted a pic of your Jeep with the hood I sold you under my post..... Project Comanche Chief..... didn't know you had a post or I would have dropped it here.... you going to make Ivy in September with us? Link to comment Share on other sites More sharing options...
bluzmj Posted August 21, 2013 Author Share Posted August 21, 2013 this is the dash that I'll be using this is the one I'm replacing finally installed the dash and a title wheel that I traded for got the 4.0 in and runnning Link to comment Share on other sites More sharing options...
