Mack4194 Posted January 15, 2013 Share Posted January 15, 2013 Is it possible to buy the little ball joint that connects the drag link to the passenger side knuckle? Thanks, Mack Link to comment Share on other sites More sharing options...
87Warrior Posted January 16, 2013 Share Posted January 16, 2013 I do not believe so. The drag link is sold as a unit from the adjusting sleeve to the knuckle. The joint is usually formed into the end of the drag link. If you need to replace it, consider using the slightly larger V8 ZJ drag link, adjusting sleeve and TRE at the pitman arm that will bolt right onto the truck. Then consider using the slightly larger V8 ZJ tierod, adjusting sleeve and TRE for a complete steering upgrade. Link to comment Share on other sites More sharing options...
Mack4194 Posted January 17, 2013 Author Share Posted January 17, 2013 Thank You Link to comment Share on other sites More sharing options...
Mack4194 Posted January 19, 2013 Author Share Posted January 19, 2013 Follow up: I got ZJ steering from the junk yard and put it on yesterday. It's a lot bigger, I never had any problems with my stock steering, but like you said it was a good time to upgrade. Thanks for the advice, I was needing to clear my lift for my friends lol. They say thank you too! Link to comment Share on other sites More sharing options...
