OverlandMJ Posted December 28, 2012 Share Posted December 28, 2012 Hey fellas. My 88 4.0 has a major exhaust leak. I can hear it when accelerating not to mention smell it in the cab. My inner shifter boot was shot so I replaced it with one for a tj thinking it would help. It didn't. I am getting smoke into the cab when I'm going 50 mph +. It looks like its coming from the trams tunnel. I did a valve cover gasket and I still have a little leak but it don't smell like oil. On the interstate in 5th it really starts smoking. I have had manifold cracks before but never smoke. Has anyone heard of this before. Do you think the manifold is the culprite? Appreciate it. -Gary Link to comment Share on other sites More sharing options...
sloride Posted December 28, 2012 Share Posted December 28, 2012 Whats your exhaust 'donut' look like? Its the fiber tapered donut that goes between the exhaust manifold and exhaust pipe. If thats shot or loose that could be a source of exhaust fumes. Link to comment Share on other sites More sharing options...
Keyav8r Posted December 28, 2012 Share Posted December 28, 2012 Check for holes in your firewall. I had a lot of smoke/exhaust smell in the cab because of a leak between the manifold and the exhaust pipe. My speedo cable is missing and the grommet is gone so the stuff came directly into the cab. I temporarily stopped the exhaust leak with a muffler repair wrap (have a whole new exhaust system to install soon, including manifold) and put some tape over the speedo cable hole (until I put my new cable in). Also bought the OEM transmission boot for a good seal there. That's solved the exhaust gas in the cabin for now. Link to comment Share on other sites More sharing options...
OverlandMJ Posted December 28, 2012 Author Share Posted December 28, 2012 I do have a few spots where there is no grommet or just an open hole in the firewall. I will grab a new donut and re do the connection between the manifold and down pipe and block off the holes. Ill let yous know how it works out. Thanks! -Gary Link to comment Share on other sites More sharing options...
