Ok, so when I fill my tank up, it shows it at about 3/4 tank. So obviously my sending unit is off. Is there a way to adjust it? Or do I need a new one.
How hard are they to replace.
Give those who know about these things a chance to read the thread... It'd been less than 11 hours [and overnight, no less] since your original post before you bumped.
It depends on which sender you have. Mine (1992) is adjustable for float position
at the rheostat. Suggest you pull the sender (it's easy) and evaluate. If there isn't
an obvious adjuster, you still might be able to adjust the float angle so that the
float position more accurately reflects the fuel quantity.
Drop the rear drive shaft theres lots room just be warned. Be careful don't brake it or you may have no gauge as these are VERY hard to find.
