Guess I'll Start A Build Thread For Goose. Moderate Trail/expedition Rig
Goose started out as a humble, stock mj in Manhattan, ks. Made its way to Colorado to spend It's life as a winter truck for an elderly man. Until now.
1988 mj pioneer
258,000 original miles, 50k on rebuilt 4.0 and ax-15
Np231, stock axles and.07 gears
No a/c
Stock suspension
Added a poor man's 3" lift(slayers, shackles, add a leaf coming soon) procomp shocks and stabilize, new tie rods, ball joints, muffler, and clutch ms.
Added 3 100w kc 6" lights on top, 2 130w 6" explorers for some trail lighting, next are some reverse lights.
Took the roof rack from a buddies vw bus and made a rack for the bed, to hold camping gear.
A buddy of mane drives the "zombie slayer" jeep. Thinking I might go this route for paint.
That's it so far. Next on the list is interior, switch to buckets, console, and a sound bar.
looking good,finally i get to see what a roof rack looks like in the bed,thtas I'm I'm wanting to setup with mine is a trail/expo rig
It was really simple. 2 pieces of 2" square tubing cut to about 1/2" short on either side, welded some angle iron on the ends and drilled some holes, bolted it up.
Only thing I don't like is that the rack is made from conduit...not very strong. I may get a different one, depending on how well this one works.
i was thinking of somthing like that,but with somthing like a hood pin whare it would be easy to take off and on for camping,eventually i wanna get a roof top tent to add too it
  • 1 month later...
Time for a new bumper
'13 Rubi, 4" lift, 35" tires buried to the frame.
Took 2 winches to free him after my bumper was sacrificed.
There is a reason that they only recommend about 2K lbs for pulling with the bumper. :doh:
Anything above that you need a high rated tow hitch. :thumbsup:
No big loss on the bumper, at least it was a Fey and not OEM :)
Dang you for stealing the nicest MJ in the state of KS. They just aren't that clean around here.
White paint is good at hiding dents and scratches. Also taking pictures a little further back helps.
  • 3 weeks later...
Took it out and played with it. An offroad park here in OK holds a mud bog comp twice a year. Big alcohol injected trucks, buggys, etc. We all come watch, hit some trails or the river, or smaller mud pits.
