HOrnbrod Posted December 10, 2012 Share Posted December 10, 2012 Grade 8 axle u-bolt set, 1/2"x20 UNF thread, 8"L, 2-3/4"W. Fits D35 and D44 axle tubes. Comes with thick nuts, lock nuts, and washers. $21 shipped, Paypal preferred. Link to comment Share on other sites More sharing options...
mvusse Posted December 10, 2012 Share Posted December 10, 2012 I was under the impression the factory u bolts were metric. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 10, 2012 Author Share Posted December 10, 2012 I was under the impression the factory u bolts were metric. I believe you are right. I thought these were factory; I've had them for quite some time. Edit time. thanks for picking that up. Link to comment Share on other sites More sharing options...
91coMANche Posted December 11, 2012 Share Posted December 11, 2012 Fyi The d35 and d44 ubolts are not the same diameter. But the buyer can just measure to double check. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 11, 2012 Author Share Posted December 11, 2012 Fyi The d35 and d44 ubolts are not the same diameter. But the buyer can just measure to double check. Axle tube diameters: Dana 35 2.64" Dana 35C 2.75" Dana 44 2.75" These u-bolts were ordered for a D35C and used briefly on a D44. They will fit all. Link to comment Share on other sites More sharing options...
mvusse Posted December 11, 2012 Share Posted December 11, 2012 Axle tube diameters: Dana 35 2.64" Dana 35C 2.75" Dana 44 2.75" These u-bolts were ordered for a D35C and used briefly on a D44. They will fit all. U bolts are not supposed to be reused. They stretch when you torque them, they're not supposed to do that more than once. Link to comment Share on other sites More sharing options...
Archived
