Fs: 89 Comanche Pioneer 4.0L Lb Santa Cruz, Ca. $1200.
JeepnDale
Updated 2/15/13
For sale is my Jeep Comanche. It shows 278, 000
New Cat, new O2 sensor, Smogged and registered 2/15/13. Got a unkyard bumper, much better than what it had.
Shifts smooth, no issues.
Truck had been stolen from PO, the steering column is all jacked. It does not effect the steering in any way, or the shifter for that matter. A simple screwdriver will start the vehicle now.
The running and tail lights keep blowing a fuse.
Aftermarket turn signal assembly added, works good
Passenger door stuck shut.
Have original factory build sheet!
I am only asking for what I have into the truck.
Updated due to repairs: $1750. OBO
http://www.flickr.co...ale/8250636136/
http://www.flickr.co...ale/8205873351/
Contact Dale
devodale@yahoo.com
  • 4 weeks later...
Sorry all! I thought I would be notified if any replies to this post I started.....Just logged in to find three questions. I will answer them in order now....sorry again. I clicked on 'follow this topic' so I should get notifications now.
name='Sunstone53' timestamp='1355084748' post='364424']
do you still have the tail light wiring harness, rear split window moldings? and what differentials do you have?
[/b]
Yes, the truck is complete, so it should have the two items you asked for, split window functions fine. It is an automatic 4 speed, I think an AW4, with np231. I am not parting out the vehicle. It needs to go all together. I am seeling it as parts, as I don't want to have to SMOG it.
Do you have any more pic's you can post up here? , like the driver's side, rear, interior, engine, etc. How does it run? Other than the electrical issue,cat and colmn, is it drivable?
-THX
I will post more pics for you within the week. Runs good. but not starting currently due to starter motor going out. Yes, it is very drivable. I drove it from Richmond in the bay area to Santa cruz, Ca. no porblem.
Do u have the Comanche still
Yes I still have it.
  • 5 weeks later...
Update:
Just put a catilytic converter on it for $208.. A few days before, I took out and checked starter, it is fine. Put it back in, and it starts fine now.
Just need to SMOG it.
OH, and I found a complete steering column from a computer source at my local junkyard! WOO HOO! He can have here in 3 days, for $200. works for me!
saving for both now.
Obviously the $ has risen a bit. As is right now $1300. Still not parting out myself, but still being sold complete for parts only.
If I SMOG it and replace the steering column, I will want $2k.
Archived
