Fuel Filter
So i'm having a hell of a time finding the fuel filter..
95 engine
95 gas tank
86 Mj body
Everything on google says its above the back left tire towards the middle.. But there is absolutely nothing there
I'm so confused.
did it get removed when the 95 swap was done? it should be on the frame right around where the bed and the body meet on the drivers side
I wasnt the one that did the swap, Bought it as is.
And followed the fuel line the entire way.. Would it possibly be inside of the tank?
On a 25 year old vehicle it could be anywhere. Assuming it still has one. Did you check inside the spare tire? Originally it was located under the floorboard attached to the inside of the left hand frame rail.Almost directly under the drivers seat. Follow the gas line from the outlet in the gas tank and it should be about two feet forward. There's a good chance when they swapped engines they also swapped fuel pumps which means the filter is in the fuel tank.
