Speedometer Cable
The cable has ring at the transmission end so it has to be pulled out that way. You will also have to remove the instrument panel so you can get to the cable going to the speedo head. Remove the other end of the broken cable. Re-install the cable housing to the head. Feed the new cable into the housing. and hook back up to the tranny, or transfer case.
