jahiatt Posted December 3, 2012 Share Posted December 3, 2012 Any info on how to remove and replace the window wipes and where I can buy them would be helpful. Water pouring in , cut out the drivers front floor panel today. Only found one supplier and they are quite expensive. Also, I was running my heater today drying the floor and I was looking under the dash at everything and noticed smoke at the fuse block. The 25a fuse for the heater was getting hot. Any ideas? Also, anyone have a pic of the spare tire hanger. Its missing and the spare is in the bed. Also, no lights in dash for turn signals and emergency blinkers. They work fine outside, and you can hear the blinking in the dash, just can't see the arrows. Love to find the plastic insert for the console. Mine is cracked. I'll post some more in a few days. one more thing, 2.8 is weak as grandma, but I knew that Link to comment Share on other sites More sharing options...
flint54 Posted December 3, 2012 Share Posted December 3, 2012 If you're talking about the outside wipes, I found mine at the JY, dirt cheap. For lack of a better word, they have "biting" clips that pinch onto the door sheet metal. I remove them with the butt end of a 1 x 2, tapped with something. Work slowly from one end and you will see they come of easily. Start at the back, as the front end sort of tucks into the adjacent trim. RE: smoke at fuse block. That's not good. Recommend you pull that fuse now, until you find out why the draw is too high. Check the connections, clean the connections, You may have a blower motor heading south, RE: dash lights. Have you pulled the instrument cluster to check for bad bulbs? It's fairly easy. Four screws for the trim and six for the cluster. Link to comment Share on other sites More sharing options...
sinkrun Posted December 3, 2012 Share Posted December 3, 2012 Cherokee door wipes from a 4 door front doors are the same up to 96. What you want to do is get the inside wipes from it as there in the best condition. Then what you do is use the one inside from one door on the outside of the other door they are direct fit. Link to comment Share on other sites More sharing options...
xjrev10 Posted December 3, 2012 Share Posted December 3, 2012 Team cherokee has new parts I believe. They sure don't give those things away. http://www.teamcherokee.com/Door_and_Related_Items/index.html Link to comment Share on other sites More sharing options...
jahiatt Posted December 3, 2012 Author Share Posted December 3, 2012 Cherokee door wipes from a 4 door front doors are the same up to 96. What you want to do is get the inside wipes from it as there in the best condition. Then what you do is use the one inside from one door on the outside of the other door they are direct fit. I took the inside wipes off my 1988 cherokee and they will not work on the onside of the comanche doors. Too fat and shaped totally different. They fit over the metal seam instead of clips which the outside wipes use. Link to comment Share on other sites More sharing options...
sinkrun Posted December 4, 2012 Share Posted December 4, 2012 I have done this several times as have many on here on the club???? Link to comment Share on other sites More sharing options...
xjrev10 Posted December 7, 2012 Share Posted December 7, 2012 I have done this several times as have many on here on the club???? You use junkyard or new parts? Link to comment Share on other sites More sharing options...
sinkrun Posted December 7, 2012 Share Posted December 7, 2012 Junk yard Link to comment Share on other sites More sharing options...
Butchershop Posted December 7, 2012 Share Posted December 7, 2012 JY. - did this today. Link to comment Share on other sites More sharing options...
jahiatt Posted December 8, 2012 Author Share Posted December 8, 2012 I must be totally dumb then. The inside wipes fits over a seam, the outer wipes use the metal clips and sllides dow. I've taken the inside ones off a 1988 cherokee 4 door and wanting to put them on the outside of a 1986 comanche They are not the same. Whats going on. Everyone says they will work, whats my problem? Link to comment Share on other sites More sharing options...
sinkrun Posted December 8, 2012 Share Posted December 8, 2012 I know some other stuff on the 86 year is different from 87 up maybe there different mine were both 89`s. Happen to have a pic of them side by side? Link to comment Share on other sites More sharing options...
Butchershop Posted December 8, 2012 Share Posted December 8, 2012 Eh, I used them on the door from which they came. Find good ones and its easy peasy as my daughter used to say. Link to comment Share on other sites More sharing options...
jahiatt Posted December 8, 2012 Author Share Posted December 8, 2012 The inside are the same. Its the outside thats different, and the outside are dry rotted on the donor cherokee. Link to comment Share on other sites More sharing options...
