Engine Trouble
Fuel Pump Ballast Resistor
The white thing...on the fender. Make sure it's connected. If it is, remove both wires and jumper them with another wire, bypassing the resistor. If it isn't connected...connect it. It reduces voltage after start to lessen FP noise
