Hello mj brothers,my mj is having running problems.she starts runs for 5sekonds then dies,she won't respond to the gaspedal.she dies when i try to push down the gas pedal/Jimmy
Fuel Pump Ballast Resistor
The white thing...on the fender. Make sure it's connected. If it is, remove both wires and jumper them with another wire, bypassing the resistor. If it isn't connected...connect it. It reduces voltage after start to lessen FP noise
