jeepobsessive Posted January 9, 2006 Share Posted January 9, 2006 My project MJ had the entire driver’s side of the trans tunnel cut out by the previous owner for clearance for a flipped D300 Tcase. I’m gonna put an NP231 back in the truck & would like to have the factory Tcase shifter mounting. I have a donor ’89 XJ that I could cut a patch panel from to replace the missing section on my MJ. Anyone know if these are the same? Thanks, Head Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 9, 2006 Share Posted January 9, 2006 Close enough. They're pretty much the same until you get back towards the seatbelt mounts, then things get a little funky I think. The floor also angles slightly different. It's just sheetmetal though. I have a little friend called a sledgehammer for problems involving that. That's based on how a fullsized center console out of an XJ fits in an MJ, and what I've heard. Link to comment Share on other sites More sharing options...
