Whisslaren Posted November 16, 2012 Posted November 16, 2012 Hi folks I am wondering if there is any way possible to see if a car and an engine belongs together. For example if I buy a car without an engine together with an engine on the side. In my case it´s a question about milage. I have an engine, and I know the vin number of the car I suspect it´s from Cheers!
JENSSEN Posted November 16, 2012 Posted November 16, 2012 compnine.com is the best decoder I have seen to date,.. should give you the info on what engine should be in the car, from there you need to check the block codes to see if it matches the info from the car
Whisslaren Posted November 20, 2012 Author Posted November 20, 2012 Just tried calling my local chrysler dealer and also compnine.com. Neither could help me. The dealer couldn´t access engine block id and compnine just said no info available. Any other ideas would be appreciated If needed, VIN is: 1C8FYN8933T555125
Whisslaren Posted November 21, 2012 Author Posted November 21, 2012 Easy answer, the last 8 digits of the vin are stamped on the engine
