derjeager Posted March 5, 2007 Share Posted March 5, 2007 will the transfere case off my 86 standard trans bolt up to a 87 auto out of a wagoneer mid size :brows: Link to comment Share on other sites More sharing options...
carnuck Posted March 6, 2007 Share Posted March 6, 2007 Are we talking 4 or 6 cyl? All 4 cyl AX-5 std and '87 to '89 6 cyl std (with 3 bolt shifter BA 10/5 5 speeds) have 21 spline outputs. AX-15 (4 bolt shifter used '90 and newer) is 23 spline output. AW4 automatic used on '87 to 08/90 XJ/MJs are 21 spline (4 and 6 cyl). 3 speed auto used on 4 cyls '84 to '90 are 23 spline output (and shallow output) I put a NP208J (you can also use a NP219, NP228 or NP229) from a full size Jeep onto an AX-15 (it'll also fit 09/90 and newer AW4s with 23 spline) BUT I had to install a Dana 300 adapter ring (because the FSJ tcases are shallow input) I now have a stronger than NP231 tcase for cheap (I see them for @$150) that already has a fixed yoke output. (I was upgrading to an AX-15 at the time) Only reason I didn't install it yet is because the AX-15 probably needs a new input bearing to ensure longevity. Link to comment Share on other sites More sharing options...
derjeager Posted March 20, 2007 Author Share Posted March 20, 2007 It was a 2.8 gm i am putting an 4.0 and an auto in Link to comment Share on other sites More sharing options...
87manche Posted March 20, 2007 Share Posted March 20, 2007 not likely, get the t-case that was with the donor 4.0/trans combo. don't forget the linkages. Link to comment Share on other sites More sharing options...
carnuck Posted March 22, 2007 Share Posted March 22, 2007 You could have a NP231 or NP207 tcase with the 2.8L and std trans. It should be a 21 spline (count the teeth to be sure. A few rare T5 23 splines were used '84 to '86 when AX trans weren't available due to slowed shipping from Japan) Here's a thought for some of you guys. A Jeep 4.0L with 9xx automatic (you'd need a flexplate from a YJ with EFI and 3 speed auto to get the correct flexplate) then make a CPS hole in the bellhousing (or find a non-computerized version 999 with the stock hole) and put it into an earlier rig with EFI (or just a 4.2/4.0L with a carb setup and 4x4 904 trans) It will bolt up to the tcase in a 4 cyl 3 speed auto rig (hey! You could even do a 727 and AMC V8!) Just don't bolt them to a NP207 or it'll probably scatter first time you shift it into gear! LOL! Link to comment Share on other sites More sharing options...
mjeff87 Posted March 23, 2007 Share Posted March 23, 2007 Here's a thought for some of you guys. A Jeep 4.0L with 9xx automatic (you'd need a flexplate from a YJ with EFI and 3 speed auto to get the correct flexplate) then make a CPS hole in the bellhousing (or find a non-computerized version 999 with the stock hole) and put it into an earlier rig with EFI (or just a 4.2/4.0L with a carb setup and 4x4 904 trans) It will bolt up to the tcase in a 4 cyl 3 speed auto rig (hey! You could even do a 727 and AMC V8!) Just don't bolt them to a NP207 or it'll probably scatter first time you shift it into gear! LOL! Beware...Chuck and I found out the hard way when we converted his 2.5 YJ from auto (TF904) to manual (AX5), that the 904/909's are 23 spline output, not 21. If you start using YJ stuff, not everything behind the 2.5L is 21 spline. Jeff Link to comment Share on other sites More sharing options...
carnuck Posted March 23, 2007 Share Posted March 23, 2007 I meant to say "you 4 cyl or V6 auto guys". Sorry about that! The brain moved faster than the typing fingers! Link to comment Share on other sites More sharing options...
