jimoshel Posted October 9, 2012 Share Posted October 9, 2012 Just finished swapping the clutch master cylinder. There was some fluid leakage but I think I caught it before any damage. Question. Has anybody removed-installed this cylinder without having to remove the reservoir? Link to comment Share on other sites More sharing options...
Blue88Comanche Posted October 10, 2012 Share Posted October 10, 2012 I have swapped the Master Clutch cylinder without removing the reservoir Link to comment Share on other sites More sharing options...
jimoshel Posted October 11, 2012 Author Share Posted October 11, 2012 So how did you get the line off? The one behind the reservoir going to the slave. I'm sure it can be done but it just seemed much simpler to just get the thing out of the way. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted October 11, 2012 Share Posted October 11, 2012 some how I used my flare nut wrench set (unsure of their proper name), but to get the old one off I used vice grips. I remember that I loosened the Master clutch cyl from the fire wall to give a little more wrench room. my clutch started leaking again I haven't started tracking down the problem but more than likely remove parts tomorrow Link to comment Share on other sites More sharing options...
