Kona Posted October 6, 2012 Posted October 6, 2012 So I took apart my dash on my 88 mj to replace the heater core an found a load of mice tracks along with chewed wires and vacuum lines, got it all rewired and done now the question is: there are 2 vacuum line that go along with all the other vacuum lines to the ac/ heater trap doors that where chewed by Mickey, one is black and the other is purple, all others are connected to the actuators that control the ac doors, but this 2 I have no clue where they go since I can't find the other end! They are cluster together with all the other vacuum lines but don't go anywhere! Any idea to where this two got to? They start at The ac control ride along the ac/heater box to the passenger side and then ....???
ftpiercecracker1 Posted October 6, 2012 Posted October 6, 2012 The two lines you are talking about go out of the fire wall and go to the Vacuum ball (black line) and the heater valve(purple/pink line) If you can't see them in this pick let me know and i will do my best to point them out.
Kona Posted October 6, 2012 Author Posted October 6, 2012 I don't have that actuator to where the purple goes to, humm???
Kona Posted October 6, 2012 Author Posted October 6, 2012 Vacuum ball, you talking about the one behind the front bumper?
ftpiercecracker1 Posted October 6, 2012 Posted October 6, 2012 Yes to the vacuum ball located under the front bumper on the Passenger side, a nice place to relocate it is right under the pressure bottle. I will probably be doing this very shortly. For the purple/pink line just plug it. Its not a big deal, a lot of people delete the valve, like me for instance.
danbyrambler Posted October 6, 2012 Posted October 6, 2012 Image Not Found This might be of use as a double check Image Not Found
